Logging info sent to syslog
Is it possible to conform what logs are being sent to one of the syslog servers.
If I understand you correctly, you want to understand what level of information that syslog-ng in your device is sending to log files
To do so, perform the following procedure:
Log in to the tmsh utility by typing the following command:
tmshList the level of information that syslog-ng sends to the log files by typing the following command:
list /sys syslog all-propertiesIf you want to effect a change to the level of information that syslog-ng sends to log files, log in to the tmsh utility by typing the following command:
tmshModify the level of information that syslog-ng sends to log files by using the following syntax:
modify /sys syslogFor example, the default log level range for the authpriv syslog facility is from notice to emerg. To change the authpriv syslog facility range from warning to emerg, type the following command:
modify /sys syslog auth-priv-from warningNote: For other syslog options, use the
command from the tmsh utility.help /sys syslogSave the change by typing the following command:
save /sys config
- Paula_Livingsto
Altocumulus
save /sys config
