pranay48's avatar
pranay48
Apr 26, 2024
Error while running ansible
I am getting the following error when I am trying to run ansible script on f5 instance through jumphost
The full traceback is:
Traceback (most recent call last):
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py", line 1344, in do_open
    h.request(req.get_method(), req.selector, req.data, headers,
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/http/client.py", line 1336, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/http/client.py", line 1382, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/http/client.py", line 1331, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/http/client.py", line 1091, in _send_output
    self.send(msg)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/http/client.py", line 1035, in send
    self.connect()
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/http/client.py", line 1477, in connect
    self.sock = self._context.wrap_socket(self.sock,
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/ssl.py", line 455, in wrap_socket
    return self.sslsocket_class._create(
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/ssl.py", line 1042, in _create
    self.do_handshake()
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/ssl.py", line 1320, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1000)
During handling of the above exception, another exception occurred:
  File "/Users/pranaychowd.pinapaka/.ansible/tmp/ansible-tmp-1714109490.0885582-73185-193526554178977/AnsiballZ_bigip_command.py", line 107, in <module>
    _ansiballz_main()
  File "/Users/pranaychowd.pinapaka/.ansible/tmp/ansible-tmp-1714109490.0885582-73185-193526554178977/AnsiballZ_bigip_command.py", line 99, in _ansiballz_main
    invoke_module(zipped_mod, temp_path, ANSIBALLZ_PARAMS)
  File "/Users/pranaychowd.pinapaka/.ansible/tmp/ansible-tmp-1714109490.0885582-73185-193526554178977/AnsiballZ_bigip_command.py", line 47, in invoke_module
    runpy.run_module(mod_name='ansible_collections.f5networks.f5_modules.plugins.modules.bigip_command', init_globals=dict(_module_fqn='ansible_collections.f5networks.f5_modules.plugins.modules.bigip_command', _modlib_path=modlib_path),
  File "<frozen runpy>", line 226, in run_module
  File "<frozen runpy>", line 98, in _run_module_code
  File "<frozen runpy>", line 88, in _run_code
  File "/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible_collections/f5networks/f5_modules/plugins/modules/bigip_command.py", line 757, in <module>
  File "/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible_collections/f5networks/f5_modules/plugins/modules/bigip_command.py", line 750, in main
  File "/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible_collections/f5networks/f5_modules/plugins/modules/bigip_command.py", line 680, in exec_module
  File "/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible_collections/f5networks/f5_modules/plugins/modules/bigip_command.py", line 631, in exec_module
  File "/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible_collections/f5networks/f5_modules/plugins/module_utils/icontrol.py", line 551, in tmos_version
  File "/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible_collections/f5networks/f5_modules/plugins/module_utils/bigip.py", line 31, in api
  File "/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible_collections/f5networks/f5_modules/plugins/module_utils/bigip.py", line 52, in connect_via_token_auth
  File "/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible_collections/f5networks/f5_modules/plugins/module_utils/icontrol.py", line 239, in post
  File "/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible_collections/f5networks/f5_modules/plugins/module_utils/icontrol.py", line 194, in send
  File "/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible/module_utils/urls.py", line 1578, in open
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py", line 215, in urlopen
    return opener.open(url, data, timeout)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py", line 515, in open
    response = self._open(req, data)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py", line 532, in _open
    result = self._call_chain(self.handle_open, protocol, protocol +
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py", line 492, in _call_chain
    result = func(*args)
  File "/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible/module_utils/urls.py", line 605, in https_open
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py", line 1347, in do_open
    raise URLError(err)
urllib.error.URLError: <urlopen error [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1000)>
fatal: [hostip
]: FAILED! => {
    "changed": false,
    "module_stderr": "Traceback (most recent call last):\n  File \"/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py\", line 1344, in do_open\n    h.request(req.get_method(), req.selector, req.data, headers,\n  File \"/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/http/client.py\", line 1336, in request\n    ..
payload.zip/ansible_collections/f5networks/f5_modules/plugins/module_utils/bigip.py\", line 52, in connect_via_token_auth\n  File \"/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible_collections/f5networks/f5_modules/plugins/module_utils/icontrol.py\", line 239, in post\n  File \"/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible_collections/f5networks/f5_modules/plugins/module_utils/icontrol.py\", line 194, in send\n  File \"/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible/module_utils/urls.py\", line 1578, in open\n  File \"/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py\", line 215, in urlopen\n    return opener.open(url, data, timeout)\n           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py\", line 515, in open\n    response = self._open(req, data)\n               ^^^^^^^^^^^^^^^^^^^^^\n  File \"/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py\", line 532, in _open\n    result = self._call_chain(self.handle_open, protocol, protocol +\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File \"/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py\", line 492, in _call_chain\n    result = func(*args)\n             ^^^^^^^^^^^\n  File \"/var/folders/4c/dnty3w814gxd01c5lq6910nr0000gn/T/ansible_bigip_command_payload_rjjis8dv/ansible_bigip_command_payload.zip/ansible/module_utils/urls.py\", line 605, in https_open\n  File \"/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/urllib/request.py\", line 1347, in do_open\n    raise URLError(err)\nurllib.error.URLError: <urlopen error [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1000)>\n",
    "module_stdout": "",
    "msg": "MODULE FAILURE\nSee stdout/stderr for the exact error",
    "rc": 1
