sergio_ordaz
Jan 07, 2020Nimbostratus
Which device should be active after a failover
Hi to all,
I am studying and doing some labs, an I want to know if there is a some kb or documentation where it says which device should be active after and split-brain event. For example:
cm traffic-group /common/traffic-group-1 {
ha-order {
/common/bigip1.local
/common/bigip2.local
mac 12:13:14:15:16:17
unit 1
also if in the case is that the fail-over method is load-aware and what will be the active member if they have the same utilization.
I tried these labs but could not find any documentation of these test.
Thanks in advance
