15-Feb-2020 13:37
Hi Team,
I am trying to Disable Weak Cipher still getting following result.
NULL ciphers (no encryption) not offered (OK)
Anonymous NULL Ciphers (no authentication) not offered (OK)
Export ciphers (w/o ADH+NULL) not offered (OK)
LOW: 64 Bit + DES, RC[2,4] (w/o export) offered (NOT ok)
Triple DES Ciphers / IDEA not offered (OK)
Average: SEED + 128+256 Bit CBC ciphers offered
Strong encryption (AEAD ciphers) offered (OK)
I have used following Ciphers list.
TLSV1_2:!DES:!3DES:!ADH:!EXPORT
What I need to add more to block LOW: 64 Bit + DES, RC[2,4] (w/o export)
15-Feb-2020 23:25
you can try the below
DEFAULT:!TLSv1:!RSA:!TLSv1_1:!3DES:!AES:!CAMELLIA:!DHE:@STRENGTH
16-Feb-2020 00:27
BIP-IP release is 14.0.0.2
16-Feb-2020 02:42
Hussian's answer should be correct.
16-Feb-2020 00:30
Earlier it was giving weak cipher for Anonmymous, low and Tipple DES.
I entered below:
After this they rechecked and they are just getting 1 again
What value I need to Add more to above ciphers.
Second what we just have only to enable TLSV1.2 only what I did in above ciphers.
16-Feb-2020 06:34
What is purpose of using DEFAULT in start is it must of use I have TLSv1.2 turned on that is required
16-Feb-2020 06:43
What is purpose of using DEFAULT in start is it must of used as I have to enable TLSv1.2 turned on
16-Feb-2020 07:41
F5 is already disabled all ssl n tls1.0 n tls1.1 ciphers in v14.x.
I don't thing any difference in keeping DEFAULT in begining.
You can check in bash mode
tmm --clientciphers 'DEFAULT:TLSV1_2:!DES:!3DES:!ADH:!EXPORT'
vs
tmm --clientciphers 'TLSV1_2:!DES:!3DES:!ADH:!EXPORT'
