Sort By
- Vijay_ECirrus
It could just be normal functioning based on persistence and incoming connection. Provide config details.
- habib_KhanNimbostratus
Check what is the persistence set. run command show sys connection | grep virual ip and make sure what are servers connection landing on. For me looks like persistence issue. Share your VIP and Pool configuration if you can.
- Jad_Tabbara__J1Cirrostratus
Hello Arun,
Could you share the output of following command,
tmsh list ltm pool pool-name members | grep -i "priority-group"
Replace the pool-name by your pool.
Maybe you have activate the "Priority Group" and you have two groups.
