RudiVanSchalkwy's avatar
RudiVanSchalkwy
Jul 17, 2019
Solved
TMSH Command via Python SDK
I was hoping to get some assistance in executing TMSH commands via the Python SDK. From the documentation i can easily execute any BASH command but i'm struggling with TMSH commands.
I need to execute the following including console output.
run /cm config-sync to-group Syncfailover
and slso check the status with
show /cm sync-status
  1. Expected console output for show
  2. CM::Sync Status
  3. ----------------------------------------------------------------------------
  4. Color    green
  5. Status   In Sync
  6. Summary
  7. Details
  8.          /Common/host1.company.com: connected (for 2548 seconds)
  9.          /Common/sync-fail-test (In Sync):
  10.           - all 2 devices consistent
  11.          /Common/device_trust_group (In Sync):
  12.           - all 2 devices consistent
The Documentation doesn't really give a noob like me information for achieving above. They only mention a very simple example in saving a config. ie
mgmt.tm.sys.config.exec_cmd('save')
  • >> Check Sync Status
    https://f5-sdk.readthedocs.io/en/latest/apidoc/f5.bigip.tm.cm.html#module-f5.bigip.tm.cm.sync_status
    https://f5-sdk.readthedocs.io/en/latest/_modules/f5/bigip/tm/cm/sync_status.html#Sync_Status
    >> Sync To-Group
    https://f5-sdk.readthedocs.io/en/latest/apidoc/f5.bigip.tm.cm.html#f5.bigip.tm.cm.device_group.Device_Group
    https://f5-sdk.readthedocs.io/en/latest/_modules/f5/bigip/tm/cm/device_group.html#Device_Group.sync_to
    Hope this helps.
    KR,
    Dario.
