flomkrl_29950's avatar
flomkrl_29950
Nov 09, 2007
syslog-ng + interface mgmt
Hello,
I have set syslog-ng on an F5 LTM. udp traffic was going thought 1.1 interface and not mgmt.
So i have set a specific route to force routing through eth0 for syslog server destination and add the command line on rc.local.
This work now but is it the right way to do that ?
Thanks a lot,
flo,
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    Hi flo -
    Yes, that is correct.
    The default route for LTM trumps the default route for mgmt, so if you have locally-generated traffic that should use the mgmt interface, you need to set a specific mgmt route for that traffic.
    More here: Click here
    /deb
