14-May-2012 19:11
ssl client profile is used but no ssl server profile
can I use SSL::enable in irule to enable ssl for some specific purpose
thanks in advance
15-May-2012 11:35
Yes. You can do that.
Just create a qualifying iRule event and enable SSL for it.
Example:
when SERVER_CONNECTED {
if { ([string tolower [LB::server pool]] eq secure.server.pool ) } {
SSL::enable serverside
Hope this helps.
15-May-2012 17:51
there is no ssl profile in server side
18-May-2012 09:08
You can just make a few modifications to your Virtual Server and iRule logic and it would work.
1. Apply the desired SSL Profile to the Virtual Server.
2. Change your iRule logic so that it will DISABLE the Server SSL Profile unless certain criteria are met. So if you only want one URI to use it then you disable it for everything that is not that URI(s).
Like this:
if { not ([HTTP::uri] starts_with "/mytargeturi/" ) or not ([HTTP::uri] starts_with "/myothertargeturi" ) } {
SSL::disable serverside
Hope this helps.
21-May-2012 18:13
thanks
so
it doesn't work ,right?
