luoye
Aug 28, 2017Nimbostratus
SOAP Monitor Failed
Hi all:
I builded a soap monitor,but it failed. Big-ip 11.5.4.Here is the debug log:
endpoint = http://170.100.130.107:9080/ImageAdminPortal/services/ProcessMessage
namespace = http://www.topcheer.com/ method name = processRequest param name = xml param type = string param value = return type = string return value = fault = 0 debug = 1 SOAP action = (null) SOAPHTTPProtocol::Close() SOAPProtocolBase::Close() CLOSED Adding string parameter xml = (string)
who can give me some advices??thanks
