Setting up a route
bcarreker
Cirrus
Cirrus
I'm setting up a new F5 in Azure with the following IPs:
internal self IP: 172.20.0.100
external self IP: 172.20.068
Both of these interfaces are displaying as UP.
I have also created a quad zero default route:
Destination: 0.0.0.0
Netmask: 0.0.0.0
Resource : Use Gateway
Gateway Address: 172.20.0.93
I am trying to ping my DNS server (also included in my DNS Lookup Server List) at 172.20.0.105. It is pinging from my internal interface, and saying DESTINATION HOST UNREACHABLE. Telnet does not work (of course) and displays NO ROUTE TO HOST.
Is there something else I'm missing here?
7 REPLIES 7
Philippe_CLOUP
F5 Employee
F5 Employee
Hi bcarreker,
can you confirm your internal and external self IPs and netmasks ? As it is unclear why you define them in the same network if i read correctly.
Yoann_Le_Corvi1
Cumulonimbus
Cumulonimbus
Hi
The VLAN configuration could also be of use.
Yoann
bcarreker
Cirrus
Cirrus
Hello, I've included the VLANs below.0691T000005oaBZQAY.png0691T000005oaBFQAY.png
Yoann_Le_Corvi1
Cumulonimbus
Cumulonimbus
Hmm strange...
Just to make sure, just run :
netstat -nr
via SSH
Then ping the default gateway, and run
arp -an
Might be something wrong at L2, but if so might be on azure's side ?
Yoann
bcarreker
Cirrus
Cirrus
The ARP command returned a lot. I copied the first page of it. ​I think it may be an issue with azure as well. I'm not entirely sure though.
