Selective request of Certificate and passing in header rule
New to irules so bear with me. Trying to create an irule that will only request a client cert for certain urls so I will not have the SSL client setting for the profile requesting the cert for all requests. We are passing this cert to an Oracle App Server for login purposes. I have 2 irules in test that both accomplish a piece of what I want but having trouble getting it all together. The 1st rule only requests cert for a particular URL and errors out OK. The 2nd rule works to pass the cert properly for our login configuration but it is assuming that the LB has already requested the cert from the browser through the ssl client profile. I am missing something with the flow here to get these 2 together. Any help GREATLY appreciated.(BIG-IP 10.0.1)
will request the cert like I want
brad-test1
when CLIENT_ACCEPTED {
set session_flag 0
set cert_error 0
set allzeros [string repeat "0" 64]
if { [HTTP::uri] ends_with "certinfo.jsp" } {
log local0. "Certificate required for: [HTTP::uri]"
Remaining issue is cashed sessions and how to deal with them b/c afer a failure the session will pass through the check
if { [SSL::cert count] == 0} {
log local0. "No cert found. Holding HTTP request until a client cert is presented..."
HTTP::collect
log local0. "HTTP::collect"
set session_flag 1
log "session_flag 1"
SSL::authenticate always
log local0. "SSL::authenticate always"
SSL::authenticate depth 9
log local0. "SSL::authenticate depth 9"
SSL::cert mode request
SSL::cert mode require
log local0. "SSL::cert mode request"
SSL::renegotiate
log local0. "SSL::renegotiate"
set id [SSL::sessionid ]
set the_cert [session lookup ssl $id]
log local0. "we are here near the end"
log $id
log $the_cert
else {
HTTP::redirect ""
log local0. "HTTP::redirect to ssologin_nocert.php"
else {
log local0. "No certificate needed for: [HTTP::uri]"
when CLIENTSSL_HANDSHAKE {
log "cert count=[SSL::cert "count"]"
set ssl_cert [SSL::cert 0]
set sid [SSL::sessionid]
Trying to test and see if i can force a check for certs? set ask [session lookup ssl $sid]
log $ssl_cert
log $sid
if { [SSL::cert count] == 0 } {
log local0. "when client handshake,ssl cert count is 0,pass"
if { $ssl_cert == "" && $session_flag == 1} {
log local0. "this is our second pass and the cert is still null "
This event could be caused by an invalid cert, card, and or pint.
How can we capture the failure and present it to an alternative page?
set cert_error 1
log local0. $cert_error
log local0. $session_flag
Currently the release will happen for the authentication but will contain a redirection
to the cac issues page
HTTP::release
if { ssl_cert != "" } {
log "cert is nothing"
else {
log "test 2"
log "when clent handshake , two way cert founded and the cert count is [SSL::cert "count"] "
HTTP::release
log "test 4"
when HTTP_REQUEST_SEND {
log "HTTP_REQUEST_DATA"
when HTTP_RESPONSE {
log "HTTP_RESPONSE"
if { $cert_error == 1 && $session_flag == 1} {
HTTP::respond 200 content {hum}
HTTP::redirect ""
log local0. "ah s hit 333333333"
set session_flag 0
set cert_error 0
Lets clean up the failed session
SSL::renegotiate
SSL::session invalidate
Will pass the cert like I need it
brad-test2
set cur [SSL::sessionid]
set ask [session lookup ssl $cur]
if { $ask eq "" } {
session add ssl [SSL::sessionid] [SSL::cert 0]}
when HTTP_REQUEST
HTTP::header replace HTTPS on
set id [SSL::sessionid]
if { $the_cert != "" }
log local0. "[X509::whole $ssl_cert]"
log local0. "what is going on.."
HTTP::header insert SSL-Client-Cert [ join [string trim [string map { "-----BEGIN CERTIFICATE-----" "" "-----END CERTIFICATE-----" ""} [X509::whole $ssl_cert ] ] ] "" ]
log local0. "ok now we know that we have a cert count > 1 can we assume that thats a valid cert?"
log local0. "**************************************************************************************"
log local0. [ join [string trim [string map { "-----BEGIN CERTIFICATE-----" "" "-----END CERTIFICATE-----" ""} [X509::whole $ssl_cert ] ] ] "" ]
log local0. "*************************************************************************************"
set headernames [HTTP::header names]
log local0. $headernames
set headersslclientcertvalue [HTTP::header value SSL-Client-Cert]
log local0. $headersslclientcertvalue
log local0. "We know that the cert has something ******************************"
log local0. $the_cert
HTTP::respond 200 content "
Access Denied
Access to this resource is denied without a valid
DOD Common Access Card. If you do not have one,
please visit the Assistance Nightmare website for information on obtaining a CAC card. Otherwise, please insert your CAC card into your reader, close this window, and try accessing this website again.
