youssef1's avatar
youssef1
Nov 12, 2019
Retrieve node fqdn or node name using an Irule
Hello Guys,
I want to retrieve using an irule the fqdn of the node.
As you know we can create a node using 2 ways: with IP or Fqdn.
In my way I create node only unsing FQDN and what I need is to retrieve FQDN value or Node name (I don't want IP add).
Second point I know that I can use Reverse dns an retrieve Arecord of my node but in my situation I can't because I have several Arecord on the same node.
Second point I know that I can use a DG with with a correspondence table which can be enriched with an ICALL or others but I wanted to see if there were some more simple things.
Last important information, I am migrating an apache configuration, and apache does it in a native way using the following command:
ProxyPreserveHost Off
This command allow to replace Client Host value by fqdn node...
Thank you for your help.
Regards,
  • Hi Guys,
    I wish to industrialize it, it is for this reason that I look for some things of standard or which can easily be put in place.
    I have to deploy it on more than 1500 services ...
    regards
