PSritaC's avatar
PSritaC
Feb 19, 2020
Redirection iRule Request for subsites
Hello
I am pretty new to F5 and would like to see if someone can help me with a redirection iRule.
The redirection should retain path after the second location or the subsites. So I am looking for something like:
1. when going to http://abcsp/sites/apps should be redirected to https://apps.abcsharepoint.example.com/
2. when going to http://abcsp/sites/apps/SomethingSomething should be redirected to https://apps.abcsharepoint.example.com/SomethingSomething
3. when going to http://abcsp/Anythingotherthansites should be redirected to https://abcsharepoint.example.com/
What I have in place right looks something like this:
switch -glob [string tolower [HTTP::host]] {
"abcsp" {
if { [HTTP::uri] starts_with "/sites/apps/" } {
HTTP::redirect "https://apps.abcsharepoint.example.com/"
elseif { [HTTP::uri] starts_with "/" } {
HTTP::redirect "https://abcsharepoint.example.com/"
This is doing only 1 and 3. 2 is missing...
Thanks in advance!
  • So if you want to do this programmatically then you need to retrieve the parts of the path. To do that, use the command [ getfield [HTTP::path] "/" <field number> ] getfield HTTP::path. You can also use the tcl split command to split the path into a list and check the list contents with lindex
    Seems pretty simple - the pseudocode would be:
    if field 2 == "sites"
        if field 3 != ""
            then Host = field 3.blahblah.com
        endif
        if field 4 != ""
            then new URI = /field3
        endif
        redirect to $Host$URI
    else
        redirect to other page
    endif
    Hopefully you can work it out from this
