paulooliveira
Altostratus
Nov 09, 2023Problems with SSL profiles with Proxy SSL and Proxy SSL Passthrough enable
Hi All
I need to redirect connections with another URL to another pool.
VS has SSL passthrough enabled, but my irule does not work.
if { ([HTTP::uri] equals "/accessapp") } {
pool pool_accessapp
I have the same irule in other VS, but with SSL passthrough disabled.
Regards
paulooliveira If you are not decrypting traffic at the F5 you cannot perform the redirect on the F5.
