Sort By
- psilvasAltostratusin Users>Groups>Dynamic Group Mapping you should be able to create a Group Mapping sequence (fallback to authenticate against), then in Master Group Mapping Table, map the RADIUS/AD group to a FirePass group. hope that helps.
- touchring_93818NimbostratusThank you.
- Noppadon_PanyarNimbostratushow about if the first radius doesn't down but it doesn't has that user on its database, then firepass try requesting on second radius server? is it possible? please advice.
