Need Help with I-Rule
We have deployed F5 in Azure it has limitation that we can only deploy one Virtual server on it , we have deployed a Virtual Server with all service ports but it has both SSL Client and Server profiles on it to server https traffic we now want to deploy the Virtual server with port 80 because our back end application is running on port 80 , Becuse of the limitation of Virtual server in Azure F5 iam looking for a i-rule that can forward the traffic depending on the FQDN and disable both client and Server SSL and forward the traffic to appropriate pool based on the FQDN . I have tried this i-rule what i get empty response . Any help will be appreciated .
when HTTP_REQUEST
{ switch -glob -- [string tolower [HTTP::host]] {
"seps1-tgt.paymentslab.ncr.com" { SSL::disable switch -glob -- [string tolower [HTTP::uri]] { "/processor*" { pool "tgt-dc1-trn" } } } } }
when SERVER_CONNECTED { if { $usessl == 0 } { SSL::disable } }
