Sort By
- natheCirrocumulus
Try this:
when HTTP_REQUEST { if { [string tolower [HTTP::host]] eq "abc.com" } { HTTP::redirect "www.abc.com" } }
Hope this helps,
N
Need you support to achieve the below change.. When user is trying to access http://abc.com should be redirected to http://www.abc.com
Try this:
Hope this helps,
N
