VB_95896's avatar
VB_95896
Nov 05, 2010
My ASM 4100 platform unexpectedly reboots
Hello,
My ASM 4100 platform (standalone) experiences an unexpected reboot (it happens every 10 pings) with the following error messages :
"CPU 0: Machine Check Exception: 0000000000000004
Bank 4: f655200134080813 at 0000000008cd5b00
Kernel panic: CPU context corrupt"
In the GUI, the error message was : "Configuration Utility Restarting"
My problem is similar to a known issue (SOL6580) except that it shoud not happen on a 4100 platform. The fix is apparently a BIG-IP BIOS update...
I can't connect via the console* and I am therefore restricted to SSH/HTTPS access whith a time limit of 10 pings which is very short...
(*) 19200/9600 baud, 8 bits, 1 stop bit, No parity, No flow control
I am thinking of the following solutions :
- turning off for 45 min (cool down)
- reseting to factory default
- reinstalling the software
Could you help me ?
Regards,
Vincent
