mikeshermanit_2's avatar
mikeshermanit_2
Sep 28, 2016
Solved
Monitor Testing question
How can we test a monitor on a node to confirm the send and receive strings are correct through command line?
We want to test it before assigning the monitor to a pool.
  • Two suggestions:
    1) Use curl to simulate the request.
    2) create a "dummy" pool with your member(s) and assign the monitor you wish to test with.
  • Two suggestions:
  • Two suggestions:
  • Hi Mike,
    you could also add the new monitor to your existing pool and then set the availability requirement to "At least 1 Health Monitor". In this case the pool members will remain active even if the new monitor fails.
    Note: Using a dummy pool as recommended by Ryan is still best practise.
    Cheers, Kai
