25-Mar-2020 11:29
25-Mar-2020 22:26
That is what I thought. Thanks for confirming.
25-Mar-2020 22:27
The default value of 0 specifies that there is no limit on the number of connections allowed per second. The optimal value to specify for a pool member is between 300 and 5000 connections.
____________________________________________________
07-Oct-2021 17:37
is there any document or way to check the max value
08-Oct-2021 00:40
I think below command can be used
sys license detail | grep ltm_lb_pool_member_limit
