LTM With Websense
Mohamed_Ismail1
Do I need to enable SNAT while using with Websense proxy as poolmemebers ?
1 REPLY 1
Stephan_Mierau
F5 Employee
F5 Employee
it depends, if the f5 is the default gateway for the servers, no you do not need it. If the f5 is not the gateway, yes you need it
