Ltm upgrade to 11.3 question
JB_106099
I am prepping to upgrade our LTM HA pair from version 9.4.6 to 11.3
I Know I have to go to 10.x first but do Ineed to apply the 10.x hot fixes before upgrading from 10.x to the final destination of 11.3?
2 REPLIES 2
Ajmal_2608
Hi JB what version of 10.x you have specifically?
However I recently upgraded few pairs from 10.2.1 to 11.3HF4 (F5 said that 10.2.3 would be a good option to choose) and following are the mandatory changes to take care about:
Modifications/Changes required in existing configuration:
  1. Check existing iRULES and look for the word "matchclass"
"matchclass" needs to be replaced with "class match" (Reference: https://devcentral.f5.com/wiki/irules.class.ashx)
Example:
Old syntax
if { ![matchclass [HTTP::method] equals $::safe_http_methods] }
Required syntax
if { ![class match -- [HTTP::method] equals $::safe_http_methods] }
Also in case you are using some variables like string arrays then you may modify them to a string class for better manageability (a good to have option)
Old syntax
Required syntax with “safe_http_methods” as a class
if { ![class match -- [HTTP::method] equals $safe_http_methods] }
The class/data-group will look something like:
ltm data-group safe_http_methods {
records {
DELETE { }
GET { }
HEAD { }
OPTIONS { }
POST { }
PUT { }
type string
Follow this while upgrading:
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip-upgrade-active-standby-11-3-0/1.htmlconceptid
Also the failover configuration is totally different in 11.x so you need to create the failover again, following KBs should help:
SOL13649: Creating a device group using the Configuration utility http://support.f5.com/kb/en-us/solu...13649.html
SOL13639: Creating a device group using the Traffic Management Shell http://support.f5.com/kb/en-us/solu...13639.html
v11.3.0: Manual Chapter: Creating an Active-Standby Configuration Using the Setup Utility http://support.f5.com/kb/en-us/prod...3-0/2.html
Let me know if you need more clarity on specific areas
Ajmal
kridsana
No. you can skip hotfixes. 🙂
