Sort By
- Joe_PruittCirrostratusYou might want to post this question over on the iRules forum. iControl is our Management API which is probably not what you are looking for.
I need to Limit the number of concurrent connections to a virtual server based on Source IP or source subnet, so for example a given IP or subnet can have only 5 simultaneous connections at any given time with a specific virtual server if a 6th connection comes in then I'd like to reset or simply drop the incoming SYN.
Any ideas on how to do this?
Thanks,
George
-Joe
