iRule- URI Rewrite with Pool
Hi All,
Hope you all are doing good.
I have requirement as below :-
Whenever user hit “https:// exampledev.abc.com/arcgisportal/*” LB should rewrite it to “https:// example.abc.com /arcgis/*” and pass the traffic to pool which is having pool member as 10.130.115.174:7443.
Whenever user hit “https:// exampledev.abc.com/arcgisserver/*” LB should rewrite it to “https:// example.abc.com /arcgis/*” and pass the traffic to pool which is having pool member as 10.130.115.174:6443.
Whenever user hit “https:// exampledev.abc.com/webapps/*” LB should rewrite it to “https:// example.abc.com /webapps/**” and pass the traffic to pool which is having pool member as 10.130.222.90:443.
So in third requirement , i think rewrite is not required. It just when user hit “https:// exampledev.abc.com/webapps/*” then send the traffic to pool which is having pool member as 10.130.222.90:443.
Please let me know iRule for this.
Regards,
ShashankS
