- Andy_McGrathCumulonimbus
Technically you can do this, I would look at some javascript which can be inserted into the HTML during a response, but why would you not just apply to the actual web application on the backend?
It would be a lot less work and quicker.
- SurgeonRet. Employee
AMG is right. That would be much easier. As alternative you can forward the traffic via icap servers. This requires some administrative work but it is very flexible solution and you can modify your webpage as much as you want without touching actual web servers https://support.f5.com/csp/article/K15819
- kraysco_322584Nimbostratus
The following pops up a warning banner on our SharePoint site. It includes a User Agent conditional that will bypass the banner in the event the user is connecting with an MS Product containing one of the agent strings listed.
Hope this helps.
-Kevin
when RULE_INIT { set static::notification_page { System Notification System Notification Acknowledgement of the privacy and security notice is required. Once the notice is acknowledged, you will be redirected to your requested page. Click } } when HTTP_REQUEST { set ckname NotificationDone set ckvalue 1 set ckdomain ".[HTTP::host]" set noticeMimeType "text/html" MS Office Application requests cannot process javascript prompts. Do not process for specific request for files from Office Applications. switch -glob -- [HTTP::header value "User-Agent"] { "*Microsoft Office*" - "*MS FrontPage*" - "*MSOffice*" - "*FrontPage*" - "*Microsoft Office Protocol Discovery*" - "*SOAP Toolkit*" - "*Microsoft Office InfoPath*" - "*Microsoft Office Existence Discovery*" - "*Microsoft-WebDAV-MiniRedir*" { Microsoft Office Application Request for specific file return } default { if { (not [HTTP::cookie exists $ckname]) } { HTTP::respond 200 content [subst $static::notification_page] Mime-Type $noticeMimeType } } }}
- action_-_322447Nimbostratus
This is very cool, thank you for sharing.
