01-Apr-2020 04:03
Hi Team,
Hope you all are doing great!
what is default value of Cookie parameter "SameSite" in F5 LTM i would like to change it to None.
I have tried the iRule based on article (https://devcentral.f5.com/s/articles/Set-the-SameSite-Cookie-Attribute-for-Web-Application-and-BIG-I...) , but no luck.
Can you please assist me with this iRule or if same can be achieved with any other LTM Policy.
Please help me to change the SameSite settings The field should be set to None (SameSite=None) . And also would like to know the default value.
Regards,
ShekharS
01-Apr-2020 04:22
HI Pete thanks for reply.
I did exactly same as mentioned in article , but i didn't see the "None" in SameSite Cookie when i used developer tool.
Any edit required in that ?
Regrads,
ShashankS
