Fabrizio_Chiava's avatar
Fabrizio_Chiava
May 03, 2013
iRule for email Traffic SMTP port 25
I need some help to configure an iRule based on the email domain name. So, I have a customer that balance the Sophos's outbound traffic (SMTP port 25). Unfortunately some email tagged as SPAM are NOT SPAM. So, the client needs to unlock this email to appliance, but all traffic flows to BIGIP.
I would that iRule behaves in this way:
if (Domain = @example.com) -> forward to node
else pool_default
Could you help me, please?
I'm basing to this iRule, I think it's a good way to approach to the solution:
when RULE_INIT {
      Replace this test TCL list with a "string" type datagroup
       and then delete the RULE_INIT event
     set destination_translations_class [list \
        "10.2.135.100:80 192.168.135.100:8080" \
        "10.2.135.101:8080 192.168.135.101:8888" \
  when CLIENT_ACCEPTED {
     log local0. "[IP::client_addr]:[TCP::client_port]: New TCP connection to [IP::local_addr]:[TCP::local_port]"
      Look up the destination address:port in a datagroup
     set dest [findclass [IP::local_addr]:[TCP::local_port] $::destination_translations_class " "]
     log local0. "[IP::client_addr]:[TCP::client_port]: Matched \$dest: $dest"
      Check if there was a match
     if {$dest ne ""}{
        log local0. "[IP::client_addr]:[TCP::client_port]: Using node [split $dest ":"]"
         Set the destination IP and port using the node command
Thanks a lot
Best regards
Fabrizio.
  • if (Domain = @example.com) -> forward to node
    else pool_defaulti am a bit confused. it is outbound mail, isn't it? so, what is node?? i guess domain is receipt domain and pool_default is sophos pool, isn't it?
    anyway, this is the past conversation. not sure if it is useful.
    iRule based on SMTP receiver domain
    https://devcentral.f5.com/community/group/aft/2160832/asg/50
    just my 2 cents.
  • Hi Nitass,
    thanks for your reply. Yes, it is. The iRule would balance the outbound SMTP traffic.
    Pratically, the client receive the SPAM email with the digest generated and the client should be unlock as SPAM. So, I need an iRule that bypass the load balancing and forward traffic to a specific node.
    I tried to implement the SMTP Proxy iRule but unfortunately doesn't work.
    Thank
    Regards
    Fabrizio.
