Icall script argument
Dmitry_A__Syso1
Hello!
How I can translate to icall script argument from APM via iRule? Example. I want generate user certificate SSL via APM. I wrote bash script, but it should be called with two argument - UserName and UserDomain.
Thank you!
sys icall script gcc_script {
app-service none definition { exec /home/root/scripts/certificates.sh $UserDN $DomainDN exec istats remove "GCC generate for UserDN" } description none events none
0 REPLIES 0
