Technical Forum
Custom Alert Banner
HTTPS traffic
can we create VIP to work on HTTPs protocol without using any SSL client nor SSL server profiles, and attach HTTP profile only to it.
or we must use SSL client profile to decrypt trafficwhen we attach HTTP profile, to enable F5 to inspect traffic.
1 REPLY 1
Lidev
MVP
MVP
Hello Mostafa,
If you are using HTTPs Protocol you need SSL profiles/HTTP profile unless you are doing SSL Pass-Through.
Please refer below link to get more informations :
K65271370: Most Common SSL Methods for LTM: SSL Offload, SSL Pass-Through and Full SSL Proxy
K14343463: Configuring the BIG-IP system to pass through SSL traffic
https://devcentral.f5.com/s/question/0D51T00006i7j36SAA/ssl-passthrough-ssl-offloading-and-ssl-bridging
Regards
