Parveez_70209
Oct 29, 2013Nimbostratus
http_x_forwarded_for setting query
We wanted to enable http_x_forwarded_for feauture in our HTTP as well as HTTPS Virtual-server having same VIP.
- Whenever someone hits HTTP URL, it should redirect to HTTPS.
- So, last time we applied only this to HTTP Profile( BUT Application understands only HTTPS not HTTP), not to https profile, so it didnt gave desired output, so now planning to enable http_x_forwarded_for feauture in this HTTPS profile too.
Query: Into this we are enabling 3 parameters:(http_x_forwarded_for for HTTPS profile) 1.Request Header Insert : ORIGINAL-PROTOCOL:HTTPS( kindly suggest whether this is correct or good). 2.Redirect Rewrite : all 3.Insert X-Forwarded-For : Enabled
3.The featured which we applied to HTTP(http_x_forwarded_for for HTTPS profile): , can we have the same settings: 1.Request Header Insert : ORIGINAL-PROTOCOL:HTTPS( kindly suggest whether this is correct or good). 2.Redirect Rewrite : all 3.Insert X-Forwarded-For : Enabled
Thanks and Regards Parveez
