If the web servers each have the same content for all applications, you wouldn't need a rule. The web server is performing the HTTP Host header inspection when a request comes in to determine which application or "virtual server" on the web server to pass the request to.
If at some point you want to add more web servers which don't all serve content for every application the VIP is configured to load balance for, you would need to use a rule. You would want to configure one pool for each application and configure each web server that answers for one particular application. For example, you would have a pool each for app1, app2 and app3. If one web server answers for app1 and app2, you would add it as a node to both the app1 pool and app2 pool. If there was another web server that answered for app2 and app3, you would add it to the app2 pool and the app3 pool. Then you could use a rule on the BIG-IP which inspects the HTTP host header and selects the corresponding pool.
I think the latter option is what you're trying to address. The rule for that would look like:
if { HTTP::host == "app1.example.com" }{
pool app1_pool
elseif { HTTP::host == "app2.example.com" }{
pool app2_pool
elseif { HTTP::host == "app3.example.com" }{
pool app3_pool
else {
pool default_pool
If you have a lot of different hosts to look for you would want to consider using a switch statement to evaluate the Host header value.
The pool configuration would look something like this:
pool app1_pool {
member 10.0.0.1:http
member 10.0.0.2:http
pool app2_pool {
member 10.0.0.3:http
pool app3_pool {
Does this cover what you were asking about?
Aaron
