24-Feb-2022 17:31
I am trying to sort and filter a couple of things and any help would be appreciated.
I need to sort and extract all Layer 4 traffic . There are about 500+ virtual servers and I would like to know how to sort out which of those are layer 4 traffic and which others are just plain jane virtual servers with no irules or profiles or have anything special going on besides just A to B traffic. I hope this makes sense, the customer just wants to know of what do they have, that doesn't have any logic behind the routing or traffic. I can't figure out how to extract that information easily.
28-Feb-2022 01:15 - edited 28-Feb-2022 01:16
That's not an easy task, since each single virtual server might run several possible different combinations of traffic profiles to modify traffic behavior.
Network map tool should give you a pretty straight-forward look on the configuration.
Other than that you might make a good use of the CLI to extract informations one at a time and report them in some sort of file.
For example, first you list all profiles: " tmsh list ltm virtual all one-line | egrep --color 'ltm virtual|profiles' " , then you list all NAT's " tmsh list ltm virtual all one-line | egrep --color 'ltm virtual|source-address-translation' " , then you list all iRules ..
