EastCoast_16835's avatar
EastCoast_16835
Aug 18, 2017
Solved
How to Preserve APM landing URI
A simple question on APM authentication.
Let's say the user lands to F5 APM with URI /somepage.htm for authentication.
After the APM authentication is completed successfully the user gets automatically redirected to the original URI /somepage.htm. This is OK.
However, if the user exceeds the time allowed for APM authentication, hits the white dialog "Session Expired/Timeout" and clicks on "Start a New Session", the original landing URI is lost and changed to "/". Thus after a successful authentication the user gets to the application root directory instead of /somepage.htm, which breaks the application flow.
How can we preserve the original landing URI after the APM policy timeout?
  • Hi,
    that's an issue with the javascript used when clicking the button.
    As I remember, it's hardcoded to redirect the user to /
    You must change the javascript to make sure to redirect the user to the original landing uri
    hope it help
    Yann
  • Hi,
    hope it help
    Yann
    • EastCoast_16835's avatar
      EastCoast_16835
      Thank you for the prompt response. It looks like in Customization I can replace SESSION_RESTART_URL with %{session.server.landinguri} and it works perfectly.
  • Hi,
    hope it help
    Yann
      EastCoast_16835
