alphamonk17_311
Feb 21, 2017Nimbostratus
How to modify AD attribute in variable assign expression?
Is it possible to modify an AD attribute (phone number) to a different format in an variable assign or does this require an iRule.
For example in AD the attribute "telephoneNumber" is set as "+12 34567890"
96171b94.session.ad.last.attr.telephoneNumber 13 +12 34567890
I want to remove the + and have the number in standard format, "001234567890" at the moment we can assume that all numbers will start with +12 and move on from there.
Does anyone know how to achieve this?
Cheers, AM
