Pranav_73262
Aug 28, 2013Nimbostratus
How to disable Virtual Server in LTM using TMSH command?
Hi, we need to accomplish following task using shell script/tmsh in LTM v 11.3 For maintenance purpose, we need a script which will bring down all VSs related to particular client & can bring it up on e maintenance window is over. Script should take client name as input & disble/enable all VS related to that client. Is it possible doing shell/perl script? Which commands I should use for tmsh, also will it support switch statement for looping or checking client name?
