Technical Forum
Custom Alert Banner
Help with url redirect
SY
I'm very new to F5 platform and need to work out how to do a url redirect for multiple backend servers
i am assuming creating an irule would be the best way for this solution ?
we currently have a working solution via F5 APM for remote users to connect to a public address / url
remote users connect to a url for example https://trx.company.com and are successfully authenticated and forwarded on to a back end server
there is now a requirement that if users add a specific suffix to the url they connect to they will be redirected to different back end servers
for example
https://trx.company.com/abc will be redirected to a different backend server
and
https://trx.company.com/def will be redirected to different backend server
is creating an irule the best method to provide this solution ?
and any help with the format of an appropriate irule would be much appreciated
thanks in advance
2 REPLIES 2
Hi SY,
You can use iRule or LTM Policy.
to pool:
	if { [HTTP::host] equals "trx.company.com" } {
		switch -glob [HTTP::uri] {
			"/abc*" { pool pool-abc }
			"/def*" { pool pool-def }
to node:
			"/abc*" { node 10.11.12.13 443 }
			"/def*" { node 10.12.14.16 443 }
SY
Thanks for your reply
i tried the second irule you suggested using node ip addresses and this did not work
users are only ever forwarded to the backend server associated to the original url without the extension
