15-Feb-2020 01:44
May I know under what scenarios HA group pool score contribution show zero. I have 9 out of 11 members live in the pool and but under show sys ha-group detail it shows score contribution form the pool to the group shows zero. I have 2 trunks added which has 40+40 and total score as 80. I have mentioned weight as 100 for the pool but it shows 0 in the actual contribution.
15-Feb-2020 02:01
i got the answer
Ans: If the number of available object members is less than the threshold, the BIG-IP system assigns a score of 0 to the HA group member so that the score of that HA group member no longer contributes to the overall score.
in my case I have assigned threshold as 10, but I have 9 in live..so it wont contribute to the overall score
15-Feb-2020
06:11
- last edited on
24-Mar-2022
01:07
by
li-migration
yes, you are correct. Also it is applicable for BiGIP version 13.0.0 and further.
Mayur
