GTM
RAQS
Cirrus
Cirrus
Hi All,
I am getting two IPs instead of one when i am doing nslookup of one application. Ex :-
abc.company.net Server: qwe.company.net Address: 10.22.46.80
Name: wide ip name Addresses: 10.95.67.98 10.95.21.98 Aliases: abc.company.net
GTM Conf :-
LB Pref Method :- Global Availability Alternate :- Round Robin Fallback :- Return to DNS
Please help me in resolving this issue
Regards, ShashankS
1 REPLY 1
Andy_McGrath
Cumulonimbus
Cumulonimbus
Can you share the status of the pool member Virtual Servers you have assigned to the Wide IP?
The default if all pool members is to fall back (Return to DNS) to the internal BIND DNS which will reply with multiple records if you have multiple pool member Virtual Servers configured.
You can change this behavior by changing the secondary and/or fall back methods to Fallback IP and setting the IP or None to not give any reply at all.
