Sort By
- SurgeonRet. Employee
build in bind server is not able to start. One of the possible reason syntax error in zone or bind config file.
I recommend you to open a support case
- sky_chenNimbostratus
This issue has been resolved , thanks you
Hello sky_chen,
is it possible to kown how have you solve you issue ? you have made changes on your configuration zone file ?
it'll probably help someone who's facing the same mistake 😉
I go to f5 command-line , show history , view previous history information , and then build a file on the issue.ðŸ˜
