03-Apr-2020 19:57
we have F5 3600 with version 10.2.4 and now I wana create new location HD1.3 but failed to create.
Even I cant delete any existing boot location.
admin@Site_A(Active)(tmos)# create /sys software volume HD1.
Sys::Software Status
Volume Product Version Build Active Status
CF1.1 none none none no complete
CF1.2 none none none no complete
HD1.1 BIG-IP 12.1.2 0.0.249 no failed (Can't find requested disk HD1.)
HD1.2 BIG-IP 10.2.4 870.0 yes complete
HD1.3 none none none no failed to create volumeset
03-Apr-2020 20:56
Can you add command in here?. It will be good to delete unused volume from LB.
Find the below command which may help you to delete Volume in v10.x I am using these command in V11.x
V11.x command
delete /sys software volume HD1.1
install /sys software hotfix <HOTFIX>.iso create-volume volume HD1.1
Raise the support case if still having issue.
Note:Make proper plan before migration from v10.x to V11.x
The BIG-IP release matrix : https://support.f5.com/csp/article/K9412
03-Apr-2020 22:12
still cant delete or create any new volume.
admin@Site_A(Active)(tmos)# show sys software
admin@Site_A(Active)(tmos)# delete sys software volume HD1.1
HD1.1 BIG-IP 12.1.2 0.0.249 no failed to delete volumeset
03-Apr-2020 22:52
Raise the support case.
04-Apr-2020 03:15
Ok thanks,
I will further explore it before asking tech support.
05-Apr-2020 20:48
Have your tried rebooting the box, if its standby give it a shot. I have experienced this in some of my boxes in the past and I reboot it. It has worked.
