jay_41157
May 14, 2009Nimbostratus
f5adduser
is there a similar command like f5adduser ? to delete / remove a user?
The user that was created using f5adduser does not show up in the GUI.
thanks,
thanks,
f5adduser appears to just be a wrapper shell script for bigpipe user (less `which f5adduser`). So you can use 'bigpipe user' to delete accounts (b user help).
You could also open a case with F5 asking them to add support to the f5adduser script for deleting a user. It seems like a logical extension of the existing functionality.
Aaron
