Sort By
- Tikka_Nagi_1315Historic F5 AccountWhat version of BIGIP software are you using? What modules are provisioned? Are you simply load balancing or also trying to secure the Oracle application using AFM/ASM?
- Chris_GrantEmployee
Based on our deployment guides, it doesn't look like it's officially supported yet:
https://f5.com/solutions/deployment-guides/oracle-application-server-10g-r2-big-ip-v11
This doesn't mean it won't work, but you may need to do some extra work or have a very good understanding of the underlying technology to get it to work right.
