crosson_16669's avatar
crosson_16669
Jan 15, 2013
F5 fallback pool
Assume the below config. If all the members of dns-53-A are down how does the virtual server behave? Given that there is an irule to LB members to a different pool will the VS remain up even though his default pool is currently down? I understand that a VS's status will reflect the underlying pool but does it know to check pools you may have listed in your attached irule?
rule DNS_POOL_FALLBACK {
when CLIENT_ACCEPTED {
if { [active_members "dns-53-A"] < 1 } {
pool "dns-53-B"
pool dns-53-A {
monitor all dns_monitor and dns_monitor_tcp
members {
10.0.0.14:domain {}
10.0.0.15:domain {}
pool dns-53-B {
members {
172.16.0.14:domain {}
172.16.0.15:domain {}
172.16.0.114:domain {}
172.16.0.115:domain {}
virtual dns-tcp {
snat automap
pool dns-53-A
destination 10.1.0.15:domain
ip protocol tcp
rules DNS_POOL_FALLBACK
virtual dns-udp {
snat automap
pool dns-53-A
ip protocol udp
  • i do see bigip still sending traffic to pool in irule.
    [root@ve10:Active] config  b virtual list
    virtual bar-tcp {
       snat automap
       pool foo-a
       destination 172.28.19.252:53
       ip protocol 6
       rules myrule
    virtual bar-udp {
       snat automap
       pool foo-a
       ip protocol 17
       rules myrule
    [root@ve10:Active] config  b pool foo-a list
    pool foo-a {
       monitor all fake
       members 200.200.200.101:53 {}
    [root@ve10:Active] config  b pool foo-b list
    pool foo-b {
       members 200.200.200.111:53 {}
    [root@ve10:Active] config  b rule myrule list
    rule myrule {
      if { [active_members "foo-a"] < 1 } {
        pool "foo-b"
    [root@ve10:Active] config  b self 200.200.200.253 list
    self 200.200.200.253 {
       netmask 255.255.255.0
       unit 1
       floating enable
       vlan internal
       allow default
     pool is down
    [root@ve10:Active] config  b pool foo-a|grep -i pool\ member
    +-> POOL MEMBER foo-a/200.200.200.101:53   inactive,down
     tcp
    [root@ve10:Active] config  tcpdump -nni 0.0 not host 200.200.200.10 and port 53 or icmp
    tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
    listening on 0.0, link-type EN10MB (Ethernet), capture size 108 bytes
    05:09:49.349283 IP 172.28.19.251.42883 > 172.28.19.252.53: S 1658522725:1658522725(0) win 5840
    05:09:49.349411 IP 172.28.19.252.53 > 172.28.19.251.42883: S 2911763653:2911763653(0) ack 1658522726 win 4380
    05:09:49.350324 IP 172.28.19.251.42883 > 172.28.19.252.53: . ack 1 win 46
    05:09:49.350466 IP 200.200.200.253.42883 > 200.200.200.111.53: S 992993099:992993099(0) win 4380
    05:09:49.354379 IP 200.200.200.111.53 > 200.200.200.253.42883: S 2393792889:2393792889(0) ack 992993100 win 5792
    05:09:49.354389 IP 200.200.200.253.42883 > 200.200.200.111.53: . ack 1 win 4380
    05:10:02.351209 IP 172.28.19.251.42883 > 172.28.19.252.53: P 1:7(6) ack 1 win 46 [|domain]
    05:10:02.351231 IP 200.200.200.253.42883 > 200.200.200.111.53: P 1:7(6) ack 1 win 4380 [|domain]
    05:10:02.352216 IP 200.200.200.111.53 > 200.200.200.253.42883: . ack 7 win 46
    05:10:02.451206 IP 172.28.19.252.53 > 172.28.19.251.42883: . ack 7 win 4386
     udp
    [root@ve10:Active] config  tcpdump -nni 0.0 not host 200.200.200.10 and udp port 53 or icmp
    05:11:13.351337 IP 172.28.19.251.44005 > 172.28.19.252.53:  30303+ A? www.google.com. (32)
    05:11:13.351426 IP 200.200.200.253.44005 > 200.200.200.111.53:  30303+ A? www.google.com. (32)
  • So would the VSERVER would remain up?status in gui is offline (enabled).
    VIRTUAL ADDRESS 172.28.19.252   UNIT 1
    |     ARP enable
    |     (cur, max, limit, tot) = (0, 2, 0, 2)
    |     (pkts,bits) in = (7, 3216), out = (4, 1760)
    +-> VIRTUAL bar-tcp   SERVICE 53
        |     PVA acceleration none
        |     (cur, max, limit, tot) = (0, 1, 0, 1)
        |     (pkts,bits) in = (4, 1776), out = (4, 1760)
        |     requests (total) = 0
        +-> RULE myrule
            +-> CLIENT_ACCEPTED   2 total   0 fail   0 abort
        +-> POOL foo-a  LB METHOD round robin   MIN/CUR ACTIVE MEMBERS 0/0
            |     (cur, max, limit, tot) = (0, 0, 0, 0)
            |     (pkts,bits) in = (0, 0), out = (0, 0)
                |     session enabled    priority 0    ratio 1
    |     ARP enable
    +-> VIRTUAL bar-udp   SERVICE 53
        |     (pkts,bits) in = (3, 1440), out = (0, 0)
        +-> RULE myrule
