Rahul_Yadav's avatar
Feb 03, 2020
F5 Bridge Mode using VLAN group
I want know, in F5 bridge Mode using VLAN group - why we need to define self IP address.
And one more point here, why F5 self IP address is not coming while doing TRACEROUTE.
  • > I want know, in F5 bridge Mode using VLAN group - why we need to define self IP address.
    Because you have two separate vlans, so each VLAN requires a self-IP.
    You may want to look at Virtual Wire which directly links two interfaces at Layer-2
    With a VLAN Group, arp requests/responses get passed directly between the grouped VLANs, so there is no actual routing via the self-IP. Because of this, TRACEROUTE will not see the self-IP.
    In general, VLAN groups should be used with care, as they may not always provide the results you expect or desire.
    • Rahul_Yadav's avatar
      Rahul_Yadav
      Icon for Cirrus rankCirrus
      Thanks Blakely,
      For kind response,
      Actually I am using VLAN group and assign self IP to VLAN grp.
      Does self IP required here?
