27-Feb-2020 09:02
Issue related to the command (example lines):
show sys log ltm | grep 2.2.2.2
looks like a bug in the version:
Product BIG-IP
Version 14.1.2.1
Build 0.0.4
Edition Point Release 1
I checked it with:
show sys log ltm lines 5
which provides 5 lines from ltm log including IP addresses (example lines):
02-20 02:07:09 warning nwwyy11 tmm[172]: SSL Handshake failed for TCP 1.1.1.1:1246 -> 2.2.2.2:443
02-20 02:07:09 warning nwwyy11 tmm[172]: SSL Handshake failed for TCP 1.1.1.2:1236 -> 2.2.2.2:443
02-20 02:07:09 warning nwwyy11 tmm[172]: SSL Handshake failed for TCP 1.1.1.3:1236 -> 2.2.2.2:443
02-20 02:07:09 warning nwwyy11 tmm[172]: SSL Handshake failed for TCP 1.1.1.4:1236 -> 2.2.2.2:443
02-20 02:07:09 warning nwwyy11 tmm[172]: SSL Handshake failed for TCP 1.1.1.5:1236 -> 2.2.2.2:443
when I am using one of those IPs in the command:
returns nothing, no result.
Of course, I tried:
show sys log ltm | grep '2.2.2.2'
show sys log ltm | grep "2.2.2.2"
as well, does not work, shows nothing, returns no results.
Other version:
Product BIG-IP
Version 14.1.0.6
Build 0.0.9
Edition Point Release 6
same commands, same inputs, works properly, shows results.
Yes, bash may be used as a workaround, anyway, for troubleshooting, would be great for both environments to have proper results.
27-Feb-2020 22:19
We have observed some issue when use grep commend in tmsh mode. V13 it worked perfectly but having issue on v14.x.
Run below command as a workaround.
tmsh show sys log ltm | grep 2.2.2.2
Thanks for an update.
28-Feb-2020 06:37
Default shell we are using is tmsh / tmos, so the commands I put here are placed to that shell. I mentioned that grep is working properly in bash, but, not by using tmsh as first work in command line, as the same issue appears as if the same command is being placed into the tmsh / tmos shell itself.
Running command "more", for example, to see log file, for example "/var/ltm/log" from bash is working properly, that is workaround.
Question is related to the same command in:
Product BIG-IP
Version 14.1.0.6 (Here it is working properly in tmsh / tmos)
Build 0.0.9
and:
Product BIG-IP
Version 14.1.2.1 (Here it is not working properly in tmsh / tmos)
Build 0.0.4
Again, in bash grep works in any version. I am mentioning the issue only for the F5 tmsh / tmos.
