Glen_Pekarcsik's avatar
Glen_Pekarcsik
Feb 19, 2020
F5 ASM - Using API to merge policies and itemfilter
I am trying to use the ASM API - /mgmt/tm/asm/tasks/policy-merge to merge 2 ASM Policies. In the JSON payload, there is an itemFilter section that allows to merge only certain items from the policy. I only want to merge urls, parameters, file types, and geo_locations. Does anyone know what syntax I would use to filter for those in the itemFilter in the JSON below?
POST
  "policyDiffReference": {"link": "https://localhost/mgmt/tm/asm/policy-diffs/<policyid>"},
  "addMissingEntitiesToFirst": true,
  "addMissingEntitiesToSecond": true,
  "handleCommonEntities": "ignore",
  "handleMissingEntitiesEnum": ["ignore", "accept-from-first",
  "accept-from-second"],
  "itemFilter": " "
