Sort By
- that depends on how you set up your logging, if you got through the publishers and destinations you are to able to say it is ArcSight.
- amolariCirrus
As per v11.6, the information from the manualis:
Important: ArcSight formatting is only available for logs coming from Advanced Firewall Manager (AFM), Application Security Manager™ (ASM), and the Secure Web Gateway component of Access Policy Manager® (APM®). IPFIX is not available for Secure Web Gateway. Remote Syslog formatting is the only type supported for logs coming from APM. The Splunk format is a predefined format of key value pairs.
At the moment it's not possible. I suggest you to open a case by F5 support. Maybe a RFE is existing and you can link your case to it or alternatively create a RFE.
- Sathya_BalakrisNimbostratus
hi amolari & boneyard, may I know what is RFE ?
- Curt_Kersey_115Historic F5 Account
An RFE is F5's term for a "Request for Enhancement". For APM, there is one that has already been created for ArcSight CEF formatting, 427106.
