EP1's avatar
EP1
Oct 01, 2019
Solved
Exchange 2019
Hi all,
has anyone configured MS Exchange 2019 on the F5?
Are you using iapp template?
I haven't found a template for Exchange 2019, are there any issues with 2016 iApp template and MS exchange 2019?
Best regards!
  • Hi Spela,
    Unfortunately we don't appear to have an iApp for Exchange 2019.
    K13422: F5-supported and F5-contributed iApp templates
    https://support.f5.com/csp/article/K13422
    In theory, you can try the iApp for Exchange 2016, because the iApp simply creates the configuration objects necessary to deliver the application through the BIG-IP. However, it depends how much the application has changed between Exchange 2016 and Exchange 2019. If there have been major changes, then it is likely some modifications will need to be made. It may be worth testing and then manually tweaking the configuration after it has been deployed.
    -Nathan F
  • Hi Spela,
    -Nathan F
  • Spela,
    Were you able to use the 2016 iapp template succesfully? Any changes we should know about that you had to make to the configuration in order for it to work with 2019?
    Thank you!
    • EP1's avatar
      EP1
      2016 iApp template worked, we're using it for about 3 months without any problems. No changes're needed :).
      Br,
      Spella
      • rduque481's avatar
        rduque481
        Thats good to know thank you!
        Are you using smtp and owa through there?
