23-Jan-2020 08:28
This is the long term part of a two part question, the short term was here.
I'm looking to streamline my companies Big IP Disaster Recovery process. Currently we essentially pull a UCS file from production, fenagle it a little bit, and then push it out to our Disaster Recovery device. There has to be a better way to accomplish this that is less manual. Does anyone else perform this type of service and if so, what is your methodology?
Solved! Go to Solution.
23-Jan-2020 18:52
For more details you can listen and read below items:
23-Jan-2020 18:47
It too much factors to decision when design BIG-IP HA. Normally best on your network environment, application flow, back-end database or etc.
23-Jan-2020 18:52
24-Jan-2020 05:19
Thanks, Nut. That video helped a lot. After watching that it seems to me the best way to do this is to create a sync-only group and include my HA pair that is in production as well as my disaster site Big IP.
24-Jan-2020 06:56
Please read more detail about synd-failover and sync-only before apply to your environment.
