Custom Header Monitor UDP
Hello,
I need to create a Monitor UDP that use custom header in payload (this: STUN Message type: 0x0001; Message Length: 0x0000; Magic Cookie: 0x2112A442), how i could get it?
It's better to use send string or to create a specific Irule?
I don't know where to start.
Thanks you a lot
Try hex send string.
This article is for TCP. but I guess the same is for UDP:
https://support.f5.com/csp/article/K01524704
- RadekR
Altocumulus
